Brake Line Replacement
  • Brake Line Replacement
    My brake line sprung a leak today. Just where it passes under the drivers seat. Luckily noticed it before i drove anywhere.
    Question is , is this best left to the experts or is it something worth undertaking myself. Where can I obtain brake lines?
    Also while I'm at it, I might as well fit the extended brake lines.
    Who has that link to the roughtrax part no.?
    私のホバークラフト は鰻が一杯です。
    Best ask Albannach.
      Best ask Albannach.
        Best ask Albannach.
        Ask Andy, Why?
        Has he already done a rant on this?
        私のホバークラフト は鰻が一杯です。
          Originally posted by blackpoolsparks View Post
          Ask Andy, Why?
          http://www.hiluxsurf.co.uk/forums/sh...ight=rear+axle you ask one little question........
            you do need a couple of special tools to make up a brake line... very easy if you've got them and have a bit of patience...
            would probably pay to get it done....
            the extended hoses are easy though... just swap the parts and bleed brakes through... mayaswell completely relace the fluid while you're at it
              [QUOTE=da SLUG man;513564.. mayaswell completely relace the fluid while you're at it[/QUOTE]
              Brake Fluid should be replaced every two years in my opinion. I dont go in for this guff about checking the SG or the boiling point or whatever it is that the garages check. Its best just to change it completely and its not like its expensive. This is even more important if you have ABS
              Bogus
              Сви можемо
                Just read that thread.
                Definetly doing it myself now, in the dark, with only a 10mm spanner and a hammer, wearing sunglasses. Then Im gonna drive it round to Andys to see if it stops before i run into his garage door.
                Seriously thought, Yoshie said its an inexpensive job and best left to pros.
                thanx for everyones comments
                私のホバークラフト は鰻が一杯です。
                  Ask Andy, Why?
                  I've been on the pi$$ since Friday lunchtime, so only just saw this (thanks Vince). Of course I've already had a rant on this! FFS, don't you read anything I post...
                    http://www.roughtrax4x4.com/index.php?doc=16&vid=180
                    here you go
                    lk003 for anyone that wants it aswell
