Done some more nearly there
    Originally posted by Phantom 18 View Post
    Ha had the timing 180 degrees out the first time nearly blew me ears off. And the neighbers windows.
    i have a nice pair of rover p6 exhaust manifolds that fit nicely in a surf
      That is the sound of an angel. What vehicle is that engine in?
      1985 Toyota Corolla drift car.
        Tried some p5 ones they did'nt fit ended up using some mgb ones that worked perfectly.
        monstercreations.org.uk
          Oh and I bet thats hard to drift
            looks good, any probs with diff hitting the sump?
              Not with a 4" Superlift no.
                Vince what radiator did you use I was thinking maybe using the Surf rad and mounting it upside down.
                  You feel free I would like to paint it black with white devils on.
                  sounds like a plan to me let me know when yr ready
                  • #24
                    whats a super lift then
                    • #25
                      I'm still using the 2.4 rad, mainly because it was brand new. It is only just adequate though, wouldn't like to take my truck green laning as it needs a good airflow through it. I also have a 16" pusher fan that seems to keep things under control.
                      Stein said he used a Layland Daff van radiator and that worked really well.
                      • #26
                        Its the correct way of doing a 4" front lift. relocates the lower wishbones etc.
                        keeps all angles stock.
                        • #27
                          1200 quids worth of suspension. Drops the whole front end down 4" and then I have 1 1/2" bj spacers. On the rear I have + 4" springs and +2" spacers. Plus an extra 1" of lift on the front because of the lighter engine. So plenty of clearance I also have a 6" body lift which helps.
                          • #28
                            It's like a spiffing lift only more expensive.
                            • #29
                              Hmm Leyland Daff thats interesting thanks Vince.
                              • #30
                                Awesome mate, judgeing by your avatar you need a giant lift, wot tyres are they, 37's? any pics of this "proper" front suspension lift? sounds interesting
