It is now connected to a PC with a new install of windows xp pro, with the latest printer drivers and it prints in the middle just the same, it seems to print in an A5 size, have done a couple of resets and now i have removed the rear panel and removed the two PC100 memory cards, unfortunately this has caused a bit of a problem as it now will only show an error of "0201 FFFFFFFF" so i assume i have wiped its RAM and ROM, Hmmm, not so good
Can't seem to find any error codes on the net for this printer.
Is it the one which is square shaped, with no rounded curves, with about three buttons and an angled, recessed L.C.D in the top panel? If so, try searching for a Magicolor 2/2+. I believe that is the model. If it's a slightly more curvaceous shape, I believe those were the 200* series. I could be wrong, however. I gave up working on the QMS stuff ages ago, so I could be well off the mark.
