Q- Why can't I use 4x4 mode all the time or on the roads?
A- There's drive to both axles and the front and rear axles have different turning circles. On hard/dry surfaces like tarmac there's no give on the road surface so you'll end up with windup on the transmission which can destroy it.
Permanent 4WD vehicles like Range Rovers have a differential in the transfer case to allow it to slip as you turn in circles. The Surf is not intended as a permanent 4WD vehicle
So theoretically you could drive in 4wheel drive on a hard road, as long you dont turn sharply, like on the motorway????
what do you think???
) long before you're going to need the traction to get back out of the corner.
