just recently my electric rad fan has been comeing on just after starting from cold, only for a min or so, whys that then?
fan
Might be the sender unit is on it's way out or loose connection. It's one of the senders screwed into the thermostat housing under the rad cap.Originally posted by caney View Postjust recently my electric rad fan has been comeing on just after starting from cold, only for a min or so, whys that then?
Switch on ignition, pull off the sender wires one at a time until the fan runs, then you'll know which one.
