Any one know if a 4mm diameter steel hydraulic pipe would be big enough to use for the liner of my home made fuel heater, I have made an aluminium block with 4 holes, 1 is for the water from the radiator and that is 15mm diameter with hose tails so I can clamp a pipe to each end, 2 are for glow plugs and the remaining 1 is for fuel but I would like to line it, instead of threading the block and fitting hose tails
It is made out of a 50mm diameter aluminium bar, by 100mm long.
Ill download some pics soon.
