For my next little lathe project I'm thinking of making a fuel heater of the glow-plug variety in series with a coolant heated one before it. Then once the coolant is up to temp, I can switch off the glowplug one.
So the unit wont be too big, I was looking at using one or two glowplugs directly into the fuel passage of the unit I'll make rather than heating the housing. I would like to use fairly short glowplugs so the unit isn't too deep. Can anyone recommend a likely type before I go Halfrauds and open every box on the shelf?
Also, I was planning on making the housing from ally bar as I have a load. Is brass OK for the fuel in / out connectors - I was thinking of barbed fittings much like I used on the ATF temp sender unit I built.
