Originally posted by breakdowntruck2
View Post
flexible mdf??
Can't see why it should snap if you do it yourself. Running a circular saw down it with the blade depth set to about 2/3's of the thickness should give you something very close to the pre-made stuff.Originally posted by breakdowntruck2 View Postmaybe try as joker said and cut the grooves,nasty feeling it will snap tho
you havent seen with a circular saw lolol,i meant when bendingOriginally posted by MattF View PostCan't see why it should snap if you do it yourself. Running a circular saw down it with the blade depth set to about 2/3's of the thickness should give you something very close to the pre-made stuff.
http://www.lathamtimber.co.uk/images...e%20panels.pdf
http://www.dhhtimber.co.uk/flexible_products.htm
2 suppliers my company deals with. Have personally had the flexi 6mm mdf from DHH.
Dunno if they'd supply just one sheet though - I piggy back my orders on my works order and pay cash.
Rob.
Void free marine ply is generally accepted to be better than mdf for sound quality, but mdf is a lot cheaper and easier to machine. I'd happily use mdf for a car sub.Last edited by wishbone; 28 September 2008, 01:37.
cheers for that,i'll look into itOriginally posted by wishbone View Posthttp://www.lathamtimber.co.uk/images...e%20panels.pdf
Rob.
do you have any plans for your enclosure..??
Ive jus built an enclosure for an 18" 1000W sub in the back of the surf..nothing fancy mind, just a wedge shaped box. I used 18mm MDF screwed, glued and sealed with 'sticks like shit'. The baffle board will be doubled up with another piece of 18mm when i get round to it as ive seen (properly amped) subs rip themselves out of 18mm before now.
With ref' to the plans, i dont see 'bendy' MDF being of much cop for x2 1KW subs..unles you layer it substantially. You would be better looking towards a glass fibre construction..??
the bendy was to make pretty well er bends,plan is remove rear quarter plastics,then 15 inch sub then 2 6x9s each side,i hadn't thought of fibreglass,is it fun to do??Originally posted by an1mal_69 View Postdo you have any plans for your enclosure..??
nice 118
