decal removal
  • decal removal
    Hi all as you can see the decals on my Isuzu look tatty .I removed the ones on my surf with a hairdryer they came off a treat not the case with the Isuzu the decal comes off in bitz and leaves the glue behind .is there a professional way to remove these (i hope)
    This question has been asked loads of times before. I believe most of the guys removed stubborn decals / stickers with a drill attachment called a 'caramel wheel'. I think they are available from most motor factor shops.
      but make sure you go very carefull with it,or if yr really confident use american razor blades,but i wouldn't advise it unless you have done it before,as for the glue,don't worry ,get the sticker off,then either use tar and glue removr,or carefully use petrol
        but make sure you go very carefull with it,or if yr really confident use american razor blades,but i wouldn't advise it unless you have done it before,as for the glue,don't worry ,get the sticker off,then either use tar and glue removr,or carefully use petrol and burn it off
        thats not a nice thing to do is it
          [/B][/SIZE]
          lolol,i didn't say that,it's not a shogun lolol,sounds odd but petrol does same as tar and glue remover
            used a caramel wheel on my surf ,piece of pees to use
              i know,just didn't want sumone comin back on sayin just took paint off lol
                i might try one of them then
                  went to halfords to get a caramel wheel and the 3 spotty kids had never heard of it am i being a plonka are you pulling my wasname?
                    use hot water mate it will come off
                    watch ya fingers tho
                    and it turns ya door handles a bit white so keep away from them
                    thats what i used anyhow it was a wallpaper steamer
                    a bit of tee cut after and all was fine
                      lol halfrauds,no chance try screwfix or a motorfactor
                        I said try a motor factors mate, not motor f**kers!
                          Im sure there in halfords.
                          next to the buckets of steam & the tartan paint
