Pressure Conversion
  • Pressure Conversion
    Manual says front and rear tyres should be 20kg/cm2. What's that in PSI, BAR or KPA? My guess is that 20kg/cm2 = 1961 KPA, 284 PSI and 19.61 BAR. But I'd rather someone who knew told me than rely on my own guess. I have one of those pressure thingies that plug into the ciggy lighter but these are the only three measures it has.
    284psi ffs.
    Try 32 front and backl you will be fine.
    Are you coming to the Clog on the 4th 5th July with the rest of the country?
    Brian
      If you get 284 psi in your tyres I do not want to be ANYWHERE near them if there is the slightest chance of a blow out or puncture, they would wake the bomb squad !!!!
      As Yoshie said 32 psi will do fine.
      Trev
        Wise of me to enquire then! That would have been idiot of the century territory.
        Do fancy the Clog but have a nephews 21st on the Saturday. I take it coming for a day is ok. Can someone point me to directions / arrangements? Complete novice so no laughing.
          We can soon arrange a poll for you
            Me thinks you got the decimal place wrong!!! 32 psi/ish is OK.
            If it aint broke, keep goin' till it is.
