@ Tony N
  • @ Tony N
    Your PM box is fu... etc etc.
    Have you got / can you get replacement softer bushes for the lower mount for the front TJMs I have?
    When I fitted them, I noticed that the lower bushes are extremely hard (almost nylon like) and as the lower shock mounts on the passenger side were slightly out of line initially - probably due to the stuffed OEM shock, the steel sleeve in the bush is now worn. I have since straightened the mounting tabs on the wishbone, but I'd like to replace the lower bushes with something a little more flexible if possible.
