@ SteinVatchSurfenFuhrer
  • @ SteinVatchSurfenFuhrer
    Mark - do you still have some of those brackety things for the Hi-Lift jack you were showing me at the Tech Weekend???
    um.yea as a matter of fact i do have some.
    www.overfab.uk
      I will be in need of your services, Mr Stein.
      Today, my Champion 12000ES winch and IST15000 mounting plate arrived, and a 48" Hi-Lift jack....
      all I need to do now is get them onto the truck.....with a nice bash plate/winch mount thingy......and the jack brackets.....
        ah good for you sir.do you have any idea as to what you are looking for design wise.????
        www.overfab.uk
          and your old one is being mounted in 2 weeks time...............rock on dude,hope it all goes on well.
          Non intercooled nothing.
            Let me draw it on the screen for you .......
            Can you see that - it's quite simple isn't it??
            I like that bit there, the best - the way you can access the diff and such without having to take the plate off......
            (I'll draw something up tonight and send it over)
              mmmmmmmm.yes,i see what you mean by that bit.its not bad is it.but what about if you were to do this bit like that,wouldnt that be a lot better.???
              www.overfab.uk
                Hang on, I've got Tipex all over the screen from the last version......
                  r u sure thats tipex!!!!! dirty boy.
                  www.overfab.uk
                    I'll have to work on this, print it off and talk you through it - but the space between the A bar uprights is 700mm x 250mm approx - I have a plate to mount the winch on but it's 910mm so will need to be cut to fit - and I want that to sit on the chassis bar if possible, with some bash plate coming off the bottom, and a servicable plate to continue under the truck....
                      So - when can you make it???
                        so basically all you want is a bash plate then?????
                        www.overfab.uk
                          No - I want a bash platy winch mounty thing.....
                            Dude - can you make one of these, but without the attachment hole in the middle???
                            http://www.trail-gear.com/toy-bumper.html
                              are you on about the winch mount but with out the fairlead hole.???
                              www.overfab.uk
