Help
  • Help
    the bolt thats adjusts the torsion bar has just broke and im in the middle of the left any help would be most appreciated
    Toyboata
    i now cant get the new tortion bar in
      Any help?........
      http://www.4x4wire.com/toyota/tech/torsion_bars/
        cheers. can i drive with out the torsion bolt on the left passenger saide?
          What do you need help with, you don't know how, you need a hand or you need spares??
          www.cnpbetterhomes.co.uk
            if you got the uprated torsion bars then i found they are a right pain to fit.Re.the bolts you can get new from roughtrax
              right ive got the new torsion bar in but i snaped the adjustment bolt. it will take rough tracks 3-4 working days to send me the new bolt. if anyone in the area has a spare that would be great or can i drive it with out 1?
                i'am am about 20ish miles from you with two breakers sat here
                  if thats the torsion bar bolts that great but i have no wheels at the mo, the truck is my ride
                    There still on the trucks at the moment, sorry ive hit the beer so can't drive either and working tomorrow. If your desperate i can pick you up tomorrow evening. or if you can get here tomorrow you can help yourself?
                        have u got a post code? i will bug a m8 for a lift cheers
                          wd3 9sp
                            amersham is a bit far im affraid, is anyone closer with the parts i needs
