i have developed a very bad "clonking" noise coming from under the surf, on investigating underneath i have found the rear most uv joint on prop shaft seems a bit dodgy (only changed it last year) but also the rear driverside wheel arch is saturated in what smells like engine oil, where could it be coming from ? (please don't say the engine !)
Oil in rear wheel arch
thanks for the advice guys - you were absolutely right, split seal and smashed bearing, all fixed now, thanks Roughtrax for the bits, excelant service as usualOriginally posted by The Lovely Boyo View PostIf it was an aftermarket UJ maybe it was a duff one.
The oil could be diff oil leaking out - a seal or bearing may have gone. One of my rear bearings went recently and that filled the wheel the arch and everything else under there with oil.Bunkle
Fox Hunting is Dangerous
Ha, just found this. So I'm not as dull as I look!Originally posted by Bunkle View Postthanks for the advice guys - you were absolutely right, split seal and smashed bearing, all fixed now, thanks Roughtrax for the bits, excelant service as usual
Actually, I am.
IOTY 2007 - The Original, and Best.Another member of the 'A' team
