steel wheels with a big offset
  • steel wheels with a big offset
    anyone no were i can get these, i need a bigger offset as i dont want to fit spacers
    What offset do you need?
    I got my 10" wide -32mm steels from Silverline 4x4.
      is that an extra 32mm from what you had?
        no, its the offset of the wheel. I cant remember what standard surf alloys are, but -8mm rings a bell, which means the mounting face is 24mm 'further in', but as the wheels are 10" as against 7", they stick out much further than an extra 24mm - Tony N had some of the same wheels in -50mm.
        <edit> If my quick bit of maths is correct, they stick out of the wheel arch 87.5mm more than a standard alloy.
        10" wide = 5" more than standard, or 2.5" a side (assuming no offset).
        2.5" = 63.5mm (assuming no offset) + 24mm extra offset = 87.5mm
        Looking at the truck, it seems about right...
          Andy is spot on standard are -8
          Brian
            10" is only 3" wider than standard
            =SOLD UP!=
              been on to silverline the 10x15 32 mm will have a dish of about 162 mm i think thats calculated by half the width 130 plus the 32 ithink thats the deepest i would be able to get unless i go for some american alloy. the black modulars are £60 a corner which aint that bad, thanks for the link
                hehehe, thats the trouble trying to do stuff when the boss is looking over your shoulder.
                ~62mm is more believable!
                  I got mine for £40 a pop cos I bought a wheel / tyre package.
                  Just went outside and did a quick measure. Yes, 162mm would be about right measure from the edge of the rim to the mounting hole circle.
                    White 8 spokes on my 4Runner are about -52mm
                      ..and very nice too!
                        i got some of them too.
                        Got the spare wheel today from Will also so thanks Tony
