The first of two winches fitted
  • The first of two winches fitted
    Well i finally got the first winch fitted to my transporter/trailer this evening.
    It's a 12,000lb winch from Extreme Terrain (part of the Champion group) so it should pull pretty much anything.
    All i need to do now is get the other one fitted to the Surf
    Tidy looking trailer mate what you dragging around?
    Brian
      I originally bought the trailer to take my SJ to pay days,so i was garanteed to get home after(even if the SJ died)
      It had to have a minimum bed width of 6ft to get the SJ on it as it has a 5ft 9" wheel span.
      the Sj has been garaged for the last 12 months but the trailer has been used for break downs and vehicle deliveries nearly every day. Yesterday i pulled one of my Surf's up to Manchester for an engine re-build
      I can legally put upto 3.5t on it and it gets pulled buy a Surf
      Paul
        Paul
        be carefull!!,the new tacho laws state that complete train weight over 3.5t has to have tacho!
          good shout!
          and it makes sense.......
          are you feeling well BDT?
          Alan
            good shout!
            lol yes ty,just one of things i know much about!,i work for the biggest independant recovery firm in the country!
              good advice though mate, I heard that a while ago.
              Alan
                well its def true,from our sussex yard we run 20 ish trucks,and its become a pita,i remember few years back doin brighton to aberdeen in 16 hours!,now anything over 3.5t has to be 56mph,i just hate,hence now workin in office/yard
                  Nice job Paul
                  There's always a Payback .... Ya just never see it Comin !!!!
                  Buncefield Burner
                    what are you doing with the power for the winch on the trailer? Is it gonna have it's own battery installed on a caravan sort of circuit - extra electrics plug and split charge or what you doing with it?
                    =SOLD UP!=
                      Have already run the extra cable from the upgraded batteries on the surf and they run olong the chassis and has a 400amp quick connector attached to the towbar. I did think about using the split charge/caravan hook-up but decided that the extra weight of the winch was enough without the extra batteries.
                      Tried it out last nite on my dead SJ and with the surf running on "idle-up" it worked perfectly well.
                      Paul
                        Paul
                        Fair enough then, that's actually the way i was gonna suggest doing it if it wasn't already wired I wasn't sure whether the split charge caravan system would actually keep the batteries topped up well enough. I wanna fit some sort of high current external socket on the rear somewhere, don't want it as low down as the bumper and don't want wires that thick flexing every time i open the tailgate. Got any details on the connector you used?
                        =SOLD UP!=
                          These are the connectors i got from the same people as i got the winch,they also provided the extra battery cable.The connectors are available in various sizes and ampages
                            Does that include private use? eg not for gain (paid work)?
                            I Love Wales
                              yep,anything over 3.5t
