Outter Cv Joint
  • Outter Cv Joint
    hi guys how do i get the outter cv joint off the driveshaft?
    is it just a case of boshing it with a hammer or what?
    try this
    http://toyotasurf.asn.au/techsite/cvjoints.htm
      thanks but i already looked there and it dont tell you how to get the
      outter one off the driveshaft.
        I beleieve outside the joint is a circlip that has to bve removed then the joint should slide off, but i might be mixing up the inner one
        Without Surf And Unhappy
          It has an internal circlip. Support the drive shaft in a good strong vice with some padding to protect the shaft and whack the joint with a suitable hammer.
