ford prime pump
  • ford prime pump
    hi, i have heard you can use a ford transit prime pump as a replacement for the surf one,has anyone done this? what year was the transit pump off?cheers
    It's used on most of the Ford diesels. Local factors will probably sell a compatible/pattern one. Should be under thirty quid or so. The filter is smaller, but otherwise should work fine. The filters are under a fiver too, if I remember correctly.
      hi matt, ive seen some on ebay for £20 to fit a 1995-2000 transit 2.5 diesel, i think it might be that type,
        Cast top with primer, filter unit, (approx 3" high in the middle), with a bottom cast section and a bolt that goes fully through to secure the sections together. Has tapped holes on the sides of the head/primer unit for accepting hose/pipe connectors. If it looks something like that, then yes, those are the ones.
          these were the ones i saw:
          Item number: 300200997189
          or
          Item number: 150219013934
            First one, yes. Second item is a pump.
              cheers matt,will see if motor factors have one like that tomorrow morn, thanks dan
