OME steering stabiliser
  • OME steering stabiliser
    My Old Man Emu stabiliser arrived a few minutes ago. For your info. it was cheaper than the Poocomp one and probably twice as good! The shocks are next. Anyone want to browse: www.tbruk.com
    Will be fitting within the next day or so and will let you know how she drives.
    cheers,
    chris
    Powered by Toyota!
    are the shox cheaper too?
    i want procomp+ 3inch shox, do they do a comparable item?
    Alan
      No, the shocks are about £64 ea. and as far as I know are only available in one size and are suited to their +40mm springs. Pricy but quality and designed for purpose.
      Powered by Toyota!
        Er, Procomp steering shocks are 36.25 each, OME are 49.99!
          Hi Bushwacker,
          Just been to check the Explorer site and the Poocomp ones are £54.10.
          There is Gabriel at £30-odd though.
          Powered by Toyota!
            Vince where are they at that price, getting my goodies together for next months fitting.
            Alan
              http://www.explorerprocomp.co.uk/aca...g_Dampers.html
                Procomp do two. A 'standard' one, and a heavy duty. I have the HD on my truck and it makes the big tyres controllable. With the OEM one, the steering bounced all over the place!
                  I see them now. DOH!
                  Alan
                    Fitted easily enough- for those who have had the steering recall done recently- it will make it easier to remove the ball-joint from the original steering damper.
                    The OME damper then just bolts on without the original ball-joint.
                    Er, just so nobody is confused:
                    OME- Old Man Emu £49.99
                    OEM- Original Equip. Man. (the one on your truck)
                    Procomp. HD- £55.10
                    Gabriel- £36.25 (Procomp do not make this and it`s biased towards road-use.)
                    Therefore, the cheaper OME one is a better deal as it`s easier to fit and will last longer than the Procomp one. (sorry, poocomp!)
                    Powered by Toyota!
                      I fancy getting one of those 'return to centre' stabilisers, but I can't find the link at the moment, any one got it in their favorites?
                        back in a mo.
                        Alan
                          recieved mine from r/trax this afternoon , now on truck
                          my old one was well fubarred
                            in aus vince.
                            here you go.
                            http://www.4wd1.com/hilux_solid-axle.htm#damper
                            Alan
                              surf page
                              http://www.4wd1.com/4runner_surf.htm#damper
                              Alan
