last question about my lift
  • last question about my lift
    Why es3000 in the front and es9000 in the back, why not 9000 all round?
    Where can i order LC80 springs for fast delivery- LC80 right?
    私のホバークラフト は鰻が一杯です。
    the landcruiser hd j80 springs you get from www.milneroffroad.com i have got es3000+3" all round on mine aand they seem ok
      will the hd springs give me 2 or 3 inches. i'm only after 2
      do you mean LC HDJ81?
      私のホバークラフト は鰻が一杯です。
        they will give a min of 3"
          The +3" shocks will give the rear axle more droop when off-roading, providing the anti roll bar is disconnected, otherwise +2" shocks will be OK.
          ES3000s are a little softer than the gas filled ES9000s.
            too much - will use standard +2 from roughtrax ?
            coil springs i mean
            私のホバークラフト は鰻が一杯です。
              When you adjust the torsion bars the ride up front is very harsh - perhaps the ES3000 could be a better option for the front?!
              I'd say go for it!
              but dont forget to come back an tell us if its cr*p!!
                coil springs i mean
                they are awesome springs mate.
                Im happy with mine!
                  Im happy with mine!
                  is it 2" ?- the advert says approx. 2"
                  私のホバークラフト は鰻が一杯です。
                    I have the LC springs and ES9000s all round - and it is quite a hard ride.....but I've got a fat ass so it doesn't bother me.....
                      Yeah it is. starts about 2.5" but settles down to 2"
                      Ive got spacers on mine. giving me bad angles.... i mean +4"
                      phew....
                        I fitted mine on Saturday, they have given 40mm of lift with nowt in the back. I was surprised that the free length of them was the same as the standard ones, makes them a doddle to fit.
                        Ebay search item 230357761354 !
                          How much with out in the back???
                          私のホバークラフト は鰻が一杯です。
                            I'd DEFINITELY recommend the ball joint spacers as the harsh ride you get from winding the torsion bars up to match the LC springs is transformed completely. The ride is MUCH better!
                              Thanx kimosaby, ive ordered the roughtrax springs, so hopefully not too much winding up the TB. If i dont like the ride, i'll try spacers
                              私のホバークラフト は鰻が一杯です。
