Have developed a serious wobble through the steering wheel... had balancing done.... no different... gets worse at around 40mph but goes away at motorway speeds... tyres are nearing the end of their life.... any ideas anyone?
steering wheel wobble
new tyres??Originally posted by RichyHave developed a serious wobble through the steering wheel... had balancing done.... no different... gets worse at around 40mph but goes away at motorway speeds... tyres are nearing the end of their life.... any ideas anyone?
they could have gone out of shape... but that would show up when balancing, i'd imagine?nee nar nee nar, i'm a fire engine!
Originally posted by slydoghow did they balance the wheels m8
Sometimes even when a worn tyre is balanced it will be out of shape and still balance but wobble badly . The balance only subdues the side wobble in a tyre . When a tyre gets worn it can oval , I have seen it .This may not show on balancing . If a tyre is down to 2mm - change it . It ain't worth the last 0.4mm before plod nick you .
RickRick...Member of 1st Gen club. ONE LIFE ... GET ONE !!
Also if it's a new import, bear in mind it will have been sat in the same place on it's wheels for some time, 1st at the auction, then at the docs, then a few weeks on a boat, then at the docks, then at the dealer. Most cars of 2 tons will create a flat spot on the tyres if subject to this amount of abuse, that's why for long term storage, cars should always be on axle stands with the wheels off.Originally posted by Vagrant No2Sometimes even when a worn tyre is balanced it will be out of shape and still balance but wobble badly . The balance only subdues the side wobble in a tyre . When a tyre gets worn it can oval , I have seen it .This may not show on balancing . If a tyre is down to 2mm - change it . It ain't worth the last 0.4mm before plod nick you .
Rick
If non of the above work out, try alcohol free beverages..Originally posted by RichyHave developed a serious wobble through the steering wheel... had balancing done.... no different... gets worse at around 40mph but goes away at motorway speeds... tyres are nearing the end of their life.... any ideas anyone?
