Noisy steering
  • Noisy steering
    Sometimes when I steer to lock, I get a noise that sounds like something metallic is about to be torn in two - any idea what this is???? It gets a few looks from passers by....
    Yup, nothing to worry about. It's just the steering bump-stops. A blob of grease on them (two on each side) will sort it out.
    Paul </Slugsie>
    Immortal.so far!
      I'll get the grease out later - cheers Paul!
        No problem. Scared the sh*t out of me the first time mine did it.
        Paul </Slugsie>
        Immortal.so far!
          Change the rad cap.
            more to the point i have a little red button, what does it do
            Without Surf And Unhappy
              chassis may be cracked
              like the driver
                what's all this talk of rad caps and red buttons - this is a local forum, for local people, there'll be no trouble here......and as for you David, Tubs will see to you later!
                  While people are reading this thread, can I ask a bit of advice? Can I use 4 wheel drive on the road? I have a 2nd gen 3.0. I got a 3.0 cos the heads go a=on all the 2.4s...
                    what time did you start drinking this afternoon????
                      copperslip lasts longer than grease.
                      Alan
                        Ok now time for me to sound like a total muppet................
                        1) Where does one procure said grease? Assuming somewhere like halfords would stock it, is there any particular type I need to look out for??
                        2) Where/what are the bump stops?!?!
                        Cheers guys!!!!
                          Halfords do some grease, which will do for this, or you could look online for a larger variety or your local motor factors.....
                            Nice one, once I have got my mits on the stuff where does it have to go, anyone got any pictures??
                              could even be power steering belt tensioner.
                              just a idea as my was knocking like hell everytime i turned the steering, belts were tight i thought but when me n stormy checked the motor had worked loose making the belt loose also on the tensioner. went to undo it n bolt snapped so stormy had to redrill it.
                              not saying its that but might be as my knocks when i got it on full lock still but need to grease it or put the plastic caps back on.
                              but ty that it could even have worked itself loose just a idea
