Gas or Oil shocks
  • Gas or Oil shocks
    Gonna order suspension lift kit from Roughtrax, what are the pros and cons of Gas vs Oil dampers (shock absorbers).
    BTW is anyone running this kit,
    http://www.roughtrax4x4.com/?doc=16&cid=150&vid=187
    and how pleased R U ?
    私のホバークラフト は鰻が一杯です。
    i had that kit on my old 2.4 and to tell the truth its not worth having the torsion bars on a 2" lift.You will actually get approx 1.5" lift with that kit.
    I found the torsion bars a sod to fit and not worth the extra money on that size lift.
    The standard torsion bars you have on the truck will be ok wound up 1.5"
      Theoretically less possible problems with gas, but reliability wise, either should work perfectly well. I think gas shocks have a slightly faster response time too.
        I was wondering bout that and discussing it with the Lang-Shankit Scunner, thanx you just saved me £143 + VAT
        私のホバークラフト は鰻が一杯です。
          buy some tyres first!
          and take the side steps off.
          uprated springs on back and your good to go,
          Alan
            New set of tyres to be ordered this week, cant decide if i want new wheels as well.
            Will I be able to get anything bigger than 31s if I lift by 2"
            BTW I like my sidesteps.
            私のホバークラフト は鰻が一杯です。
              you may be able to squeeze 32's on but i think it will still be a bit tight with 2" unless you plan on doing a bodylift also then you will be ok.Ideally for 33's you want a 4" lift
