Airplane on a Conveyor conundrum
This topic is closed.
  • Why is belly button fluff always blue?
    • Originally posted by gwh200 View Post
      too dear boy
      that's not nice Graham
      Brian
      • Originally posted by white akita View Post
        if the plane is travelling at 200mph along the belt then it will take off regardless of what speed the belt is turning !
        It won't take off, because the orginal post said, as I quoted earlier....
        The conveyor belt is computer controlled such that its speed is always the same as that of the aircraft - only backwards. I.e. If the aircraft is moving forwards at 10mph, then the conveyor will move backwards at 10mph.
        The plane will never travel at 200mph, the conveyor will match any speed the plane trys to travel forwards at, therefore, air speed over the wing will be zero, meaning no getty up in airy!!!!
        Sheesh.
        • Which came first, the chicken or the egg?
          • the conveyor belt would just make the wheels turn faster !
              too dear boy
              anyone else fancy a pop?
              • Originally posted by TonyN View Post
                Sheesh.
                If the wheels were spinning at a million mph an inch off the ground if you hit the go pedal what happens?? Thrust acts on the air and moves the plane forward now drop the plane an inch what's changed?
                Brian
                • Originally posted by breakdowntruck2 View Post
                  Coke please, full fat, none of that gay sugar free crap!
                  • Originally posted by BUSHWHACKER View Post
                    snap im just waitin till they are proved wrong
                    • Originally posted by yoshie View Post
                      if its on a conveyor belt how will the thrust move it forward??
                      • not going to happen mate, the wheels dont power a plane .
                          Mine is grey(ish)
                          I like the fact that someone spends so much time collecting belly button fluff and sticking it on barbed wire fences. This allows the sheep to rub up against the fences collecting lots of the stuff which is then recycled into clothing for us, the original donors.
                          Big up to the fluff collector
                          • Look, just forget all about wheels and conveyor belts. If the speed reference is to an external point, it makes no difference, the plane will fly.
                            If the speed reference is to the conveyor belt itself it wont.
                            I suggest everyone reads the original premise again and sees that both answers are correct depending on which reference you assume.
                            Lets have some truck pictures, this is boring now cos everyone is repeating themselves.
                            • Originally posted by Albannach View Post
                              Mine is grey(ish)
                              because most clothing fibres are blue and they collect there, FACT.
                                Did you even read the above
                                Because the thrust acts on the air not the belt
                                Brian
