Spacer Dimensions
  • Spacer Dimensions
    I'm at a loose end at work, so thought about raiding the workshops and making up some front diff drop spacers and some Front anti-roll bar spacers.
    Anyone know what the dimensions for them are?
    Try matt's download site
    http://forums.bauchan.org/portal/downloads.php
    www.daemon4x4.org
      Originally posted by Woodzie View Post
      Cheers, had a rake there earlier but couldn't find anything. Nothing on here or the Ausie site either, or at least nothing I could find!
        I can help with the height if you just let me know how much you wanna lift it?...
        =SOLD UP!=
          Depth is self explanetory.
          Outer diameter- 65mm
          Inner hole diameter- 22mm
            Drop, not lift
            Cheers mate, off to see what I can find
              Drop, not lift
              Lift
              the drop bracket's if you wanna keep everything at the original angles need to be the same as the height you wanna lift the truck...
              =SOLD UP!=
                Lift
                the diff spacers actually lower the diff tho and not raise it..
                  True, but you wouldn't drop the diff height unless you've done a suspension lift.
                    exactly Matt...
                      exactly Matt...
                      I can just imagine someone reading this thread later and thinking, 'what the chuff......'.
                        10,040 of my post are chuff so it don't make no difference does it now
                          Don't put yourself down mate.
                          We all know there's no way on earth you've posted just over 200 useful posts, so that number is around 200 higher.
                            ... but the diff will never be dropped lower than the original height, even if you use 1" spacers and do a 2" lift the diff will still be lifted and not dropped.and you just wouldn't lift the truck 1" and lower the diff 2" so the lift still outweighs the drop
                            =SOLD UP!=
                              i was meant to put 10,240 were chuff
