ok got round to fitting the weber today on the 1st gen,myself and vagrant had purchased a kit from america,but later found out when it had arrived,it was the wrong one.so me being me set to work and came up with my own version.i think it went quite well.rik if you go to do yours,you will need to grind a slot in the back of the 1st adaptor plate to allow for the protrusion on the exhaust manifold heat shield.and cut the two longer bolts down by at least half their original length.i must say it has a marked improvement over throttle response and power,but my engine is fubared and i need a new one,its chucking out burnt oil.worn rings.so without further a do heres the pics.
rik note the cut out for the exhaust manifold
