FET Turbo Timer
  • FET Turbo Timer
    Hi,
    We've recently got a 95 SSRG Surf which has a FET TB-308 turbo timer fitted. I've found some instructions on the internet but they are in Japanese, so wondered if anyone could shed some light on the unit, particularly as it appears to have 3 MODE options.
    Thanks
    Dave
    the set button changes between the 3 modes. the first and second modes are both auto where in the first mode the idle time rises at a much quicker rate than the second mode depending on how the car is driven. the third mode is(manual set), but if you hold the set button when you're on "auto2" you'll be able to change the idle time on the third mode in increments of 50 secs..
    1) Red is for battery
    2) Yellow is for ignition 1
    3) blue is ignition 2
    4) black is the ground
    5) white wire is the e-brake
    www.overfab.uk
      I found this, but I suspect you've already seen it.....
      http://www.fet-japan.co.jp/other-brands/pdf/TB308.pdf
        Thx Bushwacker, found the same file but unfortunately my Japanese is about as good as my Mandarin/Urdu/Swahili etc. i.e. non at all!!
        Thx Surfenstein, I'll have a play around with it based on your info.
          I wish i knew japanese
            You had seven years to learn
              im saying that because looking at vinces link, and i got one of those, and changed new batteries, and now it doesn't work, it light up but i dont know how to operate it to go back to auto mode.
                Press and hold the set/mode button.
                www.overfab.uk
                  nope, no change, turn off the key, engine turn off straight away, before was turn off with the key, lock the car, then engine turn off.
                  don't know what to do
