clatter grinding noise
  • clatter grinding noise
    i got a clatter grinding noise when iam driveing my surf
    its coming from the front pasanger side wheel some were
    no dowt i broke some thing
    i been out in the mud to day and a few flooded roads all was fine untill i parked up it was standing for a few hours
    i just been out and it sounds ruff the noise comeing from the wheel is quite noisey
    its like a clattering cross with a grinding (i just had a lot replaced all bearings on so on) so any ideas on what it could be???
    Not being funny, could you have grit in the brakes ?
      didnt we all tell u?lol,have u checked the obvious?bits hangin off etc?is it at speed?on steering lock?
        i been washed them out (in puddles tho at speed)
        i did get buryed in coal tho yesterday MMMM
          it has soon has i move it starts
          and yes every one telled me most on here every one in my house my wife told me
          but you know i just had to go out to play (i have been ill for a long time)
          needed some funn
            does it get worse if u speed up?have u had a check underneath?no boots split??
              i had a quik look but i carnt see nothing out there is realy bad weather
              but the noise just keeps going at the same rate it dont get faster or slow with the truck it just makes a loud noise like a grinding with a loud clatter to it
              its very strange noise i have heard it before on plant macheanary
              but i must have broke something or i hope its just coal stuck in some were
                what about a cv joint on the front or the uj's on the props
                  tbh honest im fairly new to surf mechanics,but my my job id say sounds like cv joint poss but u wud have noticed it gettin worse,im sure sumone will know?spose u may have knackerd a drive shaft?
                    the uj went on the rear prop on my truck a couple of weeks ago and that sounded terrible just like a grinding noise but i never actually noticed till i got under the truck and had a good look at each joint to see that 1 had snapped but still in place
                      couldnt miss the skyline one goin lol whole car vi brated!
                        Is the noise definitely coming from the wheel?
                          i had never been in a vehicle before when one has gone so i was totally stumped when mine went and paniced cause i was meant to be going up to Hampshire the following day
                            my funniest moment,my scoob goin into limp mode at 130mph,then all of a sudden no power went right down to 30mph lolol
                              If it sounds like running over a drain and you can only hear it with the window open then its the bronze bushes in the hub. £55 ish from roughtrax about an hr to fit. Took me 6 months to find out what my noise was.
                              monstercreations.org.uk
