Checking wheel size??
  • Checking wheel size??
    Hi all
    I just want to ask a quick question about wheels...if i am buying a new set for a 3rd gen and i have a choice +20 offset or +0 offset would someone mind letting me know what the difference is....i'm thinking +0 offset will stick out a little further than the +20 is that the right way of thinking or not.
    Cheers for any advise.....going to orer on line tomorrow or following day so pleeease answer quickly.
    Mat
    Nut in a Truck
    Yeah, minus numbers with stick out more. Don't know much about 3rd gen offsets, 0 offset is the mounting face bang in the middle of the rim width. Big + offsets cause rubbing on wishbones and chassis, big - offsets cause rubbing on wheel arch edges and chassis.
    Standard 2nd gen 7" wide rims are -7mm offset.
    The wider the rim, the more important the offset is.
      Here's a visual.........
        cheers bud
        Nut in a Truck
