dubious to use veg oil HELP please
  • #31
    I'm blue with a slightly saggy ar5e well the surf is I'm not blue
    • #32
      as with any other tax records you must keep records of any veg oil used as fuel for 6 years
      =SOLD UP!=
      • #33
        Cheers Nero,
        Is that just reciepts for the oil or a record of how much you put in?
        Adam
        • #34
          It's upto you mate, the reciepts tend to fade to unreadable after a couple of months anyway so some are also keeping a written record. I keep a book in the car an just write in the mileage and what I put in everytime I fill up, diesel or veg, as you would with a fleet vehicle. I think it'd be wise to show the diesel usage aswell. That way there should be no discrepencies for the IR to try and shaft you on.
          =SOLD UP!=
          • #35
            Good call nero,
            I think i'll order a fuel filter and give it a go
            Adam
            • #36
              why white spirit
              Originally posted by internetsurfer
              just pour it in mate , 20 ltrs of derv . 15 lites of veg oil and 1 ltr of white spirit or unleaded , and drive it
              Hi there
              i take it that derv is diesel, but my main question is why the white spirit.
              do you mix it all befour putting it in or just put in straight into your tank and let it do the mixing.
              Many thanks Will
              • #37
                it gives it a bit more oomph when running,aids cold starts , plus it thins the mix a bit also .
                some pre mix it , i just chuck it in and let the return and intake mix it 4 me.
                • #38
                  white spirit or unleaded.
                  thanks all.
                  going to try it out later today. im just going to chuck it all in 20 ltrs of derv, 15 lites of veg oil and 1 ltr of white spirit or unleaded.
                  which would you say is best white spirit or unleaded?
                  many thanks to all
                  surf-wejd
                  • #39
                    Originally posted by surf-wejd
                    thanks all.
                    many thanks to all
                    surf-wejd
                    i use 1l of white spirit to 15l of veg oil.give it a good shke before pouring in the tank so its well mixed
                    • #40
                      how much diesel are you mixing that with?
                      • #41
                        at the mo i am putting 10 -15l in
                        • #42
                          ok thanks will try 15L veg oil, 15L diesel and 1L white spirit.
                          • #43
                            sorry i'm putting 10-15l of fuel to 40 -45l of oil/w spirit mix
                            • #44
                              Originally posted by MTBBILLY
                              True filtering is good but it dont alf stink!
                              Mine doesn't smell,,unles you're sitting behind me in a traffic queue!!!!!
                              CHEERS
                              Paul
                              • #45
                                i still think that the white spirit is wrong,but then im probably wrong lol,but i'd be worried bout it damagin anything it touched!
