It does make a noticeable difference to the regulation with no 'stat in, doesn't it.
One thing that may be worthwhile considering if you're paranoid over temps is fitting a slightly lower temp 'stat. Normally, it's swings and roundabouts if you go too low, but parrasurfa on the Oz site has posted a part number for a genuine 82 degree 'stat for the 2.4. It's only 6 degrees below the standard 'stat temp, so may be a worthwhile consideration. As to whether it keeps the engine temps otpimal, I honestly couldn't say, as I haven't checked the thread for awhile, but the info is on there.
Originally posted by nero279
