Atf Cooler!
  • Atf Cooler!
    Finished it today, mounted in bash plate on the supply line, done alot of miles today and i can really recommend doing it. I used my aircon condenser from inside the cab under the dash, chopped it down to take hoses, and then hooked it up.
    Lower coolant temp, smoother shifting when engine is hot than before, and better pic up and acceleration when hot aswell. My pasty warmer no longer works and gear selector stays cool.
    Very reassuring. Try it
    Without Surf And Unhappy
    You trying for Stein's title????
    Piccies please.
      Piccies please.
      Terribly sorry, piccies have been taken batteries dead, they will be edited in later, thanks for your help today with iritating questions mate. Im very happy i did it.
      although i had to grind of the mounting plate and grind down the flanges on the pipes to make them round, but dont leak at all even when climbing a long steep hill
      Hoorah indeed
