Replacement Tyres
  • Replacement Tyres
    I think I have 265 70 R15's. What size can I put on the rims men? No lift at present. I'll be wanting AT's.
    you will be able to squeeze 31.10.5.15's on
    Non intercooled nothing.
      Thanks, what size is that in the format in the OP?
        Er, I dont know what an OP is, But the 31x10.50r15 will be a little bit bigger then stock!
        Obviously BFG's are the best AT's. Good road manners. Colway do a remould of the same tread pattern but with no sidewall tread stuff
        http://www.4x4tyres.com/index.php?sh...ofile=31x10.50
        Check that out, Loads of options an good prices!
          I've got these A/T's in the same size as you have, 265/70R/15's.
            265/70 R15 = 30x10.43 R15
            31x10.50 R15 = 267/76 R15
            either size will go on a standard surf.
            =SOLD UP!=
