@ Surfenstein
  • @ Surfenstein
    Heres your next PROJECT mate
    http://fullsizebronco.com/forum/showthread.php?t=25748
    Or you could make this out of the 1st GEN http://www.lowrangetv.com/play.php?vid=147
    How many Gears ????????????? 35 speed Transfer Case
    you can get that crawl ratio with simply dual cases, and 4.7 gears. Costs less than a TG SAS kit.
      First one wont load, second one is cool.
      Working at last.......
        Its you then It works for me
          Working now, what you do.
            hit it with a big hammer!!!
            Non intercooled nothing.
              NOTHING it must have been you
                Not a hammer big enough to sort me out.
                  I just tried half an hour later and it worked.
                    You work !!!!! ............
                    by the time you have had 20 fags two breaks and chatted up the pols you don't have any time to work
                    www.daemon4x4.org
                      some very nice bits of kit there,hats off to the guy building a hummer.woodzie did you notice the wall climbing unimog on the second link.
                      www.overfab.uk
                        No i'll have a look later
                        www.daemon4x4.org
                          heres a link mate.http://www.lowrangetv.com/play.php?vid=127
                          www.overfab.uk
                            Me want...........Any one know tomorrows lottery numbers
                            www.daemon4x4.org
                              I turn up, clock in, do the above, clock out, go home, whats the problem ?
                              TWO breaks, you must work on a slave labour shift, i have at least THREE.
