Rumbling noises
  • Rumbling noises
    At the top of every gear, I get a rumbling sound, I think from the transmission, that goes away when the gear changes.....any ideas what this is?????
    Next Thursday the Surf is booked into the garage for 4 new UJs, 4 sets of wheel bearings and new diff oil.....hopefully that will shut it up....
    I'm changing ATF, oil, oil & fuel filters tomorrow...
    are you sure its not engine rpm related.make sure the idiots put the ujs in properly this time.and correctly aligned.
    www.overfab.uk
      The RPM on idle is about 550...tried to adjust it but need to get the WD40 out to loosen the cable nuts.....
      Different garage this time, however - this is the bunch that spent a while explaining to me that the air con unit under the bash plate was an oil cooler, that Toyota fit as standard.......
      GOD - what have I done?? I can't wait to move, so I'll have a drive, and start doing this myself!
        Check the wheel bearings aswell
        www.daemon4x4.org
          All being changed on Thursday too
            Its probably your STOMACH mate
              It was either going to be you, Apache or Boyo - I was waiting for that.....
              But now you mention it.........
                DONNA KEBAB & A BEER usually Helps
                  Idle is awful - the whole truck is shaking......
                    maybe you have a broken engine or gear box mount.
                    www.overfab.uk
                      Hmmm - engine ones were checked not too long ago - but I'll check the gearbox ones following three weekends in Wales in quick succession....
                        If you don't know the garage and they give you a list of new parts I would ask for the old bits so you know they have actually been done.
                        But then Iv'e been fleeced before so always wary.
                        www.brydenenterprises.co.uk www.kirstyskids.org
                          Why don't you take it to Tony N? If I have got it right your in Oxfordshire, so it's not far to drive for an expert to care for your truck
                          Dean
                          "Master you anger, before anger is your master!!"
