cb ariel fixing
  • cb ariel fixing
    ok prob most of you know how to fix a cb ariel.
    but i use mine on a magmount but if you fixing through the roof youd be better off using a pl259 right angle connecter its better for the coax cable
    Okely dokely!
      Ok, but how do you fix it to the roof and maintain a good ground plane
      SWIFT AND BOLD
        your ariel will go though hole in roof n use a washer either side best if fitted in center of roof better ground plain i was going to do it but then i thought id be better off with my mag mount
