stranded in yorkshire..
    Originally posted by fatfires
    methinks if you refer to her as 'the wife' she may not be playing any tunes, my adorable would string me up by my gonads for calling her that.......that and the 'C' word, she just hates
    Yeah, 'the wife' is a bit bad. The wench is much better.
      actually i call 'her' or 'the wife' my "muffin" you lot know 'her' as 'the wife' she got no interest in this or any other forum, so it's a pretty safe bet that i'm able to call 'her' 'the wife' on these pages.
      anyhoo, been smoking them weed for too long, it messed my head right up, luckly i've spotted the problem a little while ago.
      the weed you buy now is just too strong for it to be relaxing or a bit of fun in the evening. i let it come between me and 'the wife' sent me on a paranoia trip and now i'm on my knees, to put a long story short, i never listened when my loving and very patient wife wanted me to stop. i'm hoping we can work it out, and by me working hard to make ammends, i'm sure we can.
      i don't expect sympathy, i made my own bed, but the last few months have been a nightmare, my wife has changed so much in that time, i just never saw it.
      we are working out, the holiday in yorkshire was just to clear my head out, fill it full of the quality things of life and remind me of the promise i made to my wife the day we got married. to love,honour and obey...
      plus theres my little lad to consider, what kind of example do i give to my boy?
      life has been strange and tough going over the past couple of weeks, but day by day it's getting better, i've got a long way to go, but the reward is worth it, my family, together.
      The benchmark....
        YIPPEE! all fixed, i did't realise the head was cast iron though, any hoo she's back, head skimmed, new cam belt, pump, all done...... .
        how ever, coming back last night the orange gearbox check light came on (autobox) checked the atf and it seems fine, could this be a dodgy connection to the sensor?, if i stop, turn off and start again it goes out,but comes on again under load (kick down) i drove her to tesco's this morn and it never came on,
        no vibrations, smooth gear change, everything seems ok guy's?
        The benchmark....
          Pull the fault codes just like you do for the engine, and the O/D light will flash for gearbox faults.
            how do i do that mate?
            The benchmark....
              hello?
              The benchmark....
                how do you pull the fault codes for the engine then???
                The benchmark....
                  Here are the codes for a 2LTE diesel.
                  1 - Normal
                  2 - Turbo boost pressure sensor
                  4 - Coolant temperature sensor
                  5 - Correction resistance (Pump)
                  6 - Pump speed sensor (Pump)
                  7 - Throttle position sensor
                  8 - Intake air temperature sensor
                  9 - Vehicle speed sensor
                  10 - Starter switch
                  11 - Switch sign (Vehicle not in P or N or A/C on)
                  12 - Timer control valve (Pump)
                  13 - Crank position sensor
                  Looking for diagram next
                  • #24
                    Have a look through these threads for instructions
                    http://www.hiluxsurf.co.uk/forums/se...earchid=439291
                    • #25
                      1 - Normal
                      10 - Starter switch
                      so you bridge with a piece of wire between terminals on the pc connection block?
                      The benchmark....
                      • #26
                        you marky are a star
                        The benchmark....
