@ Bushwacker
  • @ Bushwacker
    Can you pleeeeeeeeeease show me a thread on changing front shocks ta.
    Working at last.......
    I don't think there is a thread, but it's not a hard job.
    Raise the front of the truck, remove wheels.
    Undo the nuts at the top of the shocks.
    Remove the washers and cushions from the shock's shaft.
    Disconnect the shock from the lower suspension arm.
    Reverse the above to re-fit.
      Ok thanks, thats what i've been told but thought there might be some pics.
        The shocks are the long black things that squish together when you go over bumps.They are behind the front wheels.
          No there not those things are the flux capacitors, the shocks are in the boot.
            Yes they are your boots .......the shock is from the smell
            www.daemon4x4.org
