Ok, just come back from my mechanic blokes workshop, His guess is both blacks are earths and the red is main live. So.... It should be pretty simple to wire up...the complicated bit is going to be running the wires
just noticed your thread did you work out the wiring and did you get the lights to trigger when you flash or switch on your full beam i have a similar set of lights and im as confused as you were
thanks
