coolant help
  • coolant help
    hi guys,in the process of sticking a new head back on the beast but was wondering whats the best type/ quality antifreeze/coolant to use in the surf
    ethylene glycol or propylene glycol?? would a certain type damage anything in the engine as its 16 years old??! anyone used the toyota 4 life coolant? dont mind spending a bit more if it will give it an extra chance at cooling better!! cheers
    no idea what all those funny words are but I use toyota red... from toyota.
    Tim
      mmm i think ones water based and ones alcohol based but not too sure,all i know is if i drink it my kidneys bleed for a fortnight
        You want ethylene glycol I believe. Toyota red is ethylene glycol (I know that cos I changed the coolant today and that's what it said on the label )
          Blue:
          Okay. Not the best, but it'll do the job.
          Green:
          Very good. No contaminants like the blue, and will also mix merrily with blue and green antifreeze.
          Red:
          Very good. Like green, no contaminants. Will not mix with any other antifreeze though, so must be put in a perfectly clean coolant system.
          Personally, I use the Comma green.
            I use Toyota Red anti freeze. It comes pre mixed too.
            A Toyota technician that I used to work with said he wouldn't use anything else, even though it's more expensive.
