Landcruiser Springs
    Originally posted by stormforce1067
    i have also got the extended braided brake lines from roughtrax
    yea me too.they really improve the feel of the brake pedal.if you know what i mean.
    www.overfab.uk
      Right - just to clarify (can you tell I'm a consultant??)
      ES9000 +3 (just in case)
      Longer braided lines (for extra reach)
      Bolt and spacer where these join?
      Job done....
        Originally posted by scotty
        my tupansworth.
        i have es9000+3" shocks with LC springs and havent had a problem, i also havent extended my break hoses.
        and i give it some sh*t off road, with the rear end cocking a leg a lot and have never had a problem.
        TOTAL DITTO!
        When I was going through all my shyte with Procomp, I made some U section brackets to extend my OEM shocks. They handled the Plain at Crimbo no probs.
        BTW - you have to tell Procomp the part number you want - DO NOT verbally order your bits - they will get it wrong.
          Job done....
          es3000+3 or es9000s+3
          bolt and spacer.no need to get braided lines if your not gonna do a body lift.
          vinces drop bracket kit
          hjd80 rear coils springs.
          www.overfab.uk
            i still got to fit the front ones yet
              havnt you done that yet???be carefull when you do,i had to twist mine then tighten them up so they didnt rub on the chassis and tyres on full lock.
              www.overfab.uk
                Oh yeah - the springs.....
                What is in Vince's kit??? and where is he?
                  i might just get the garage to do them and then they can bleed the brakes thru properly then
                  • #24
                    Hello there!
                    http://hiluxsurf.co.uk/forums/showth...ache+mickeyboy
                    • #25
                      panhard rod drop bracket,rear arb drop brackets.and all the hardwear including the spacer for the flexi hose.oh and you will also need to adjust the little bracket that holds the load sensing valve arm.
                      www.overfab.uk
                      • #26
                        Blimey!
                        • #27
                          Blimey!
                          Like I said - do not go it alone!
                          There's lots of learning been done on this site!
                          • #28
                            yea as we found out eh andy.old bolt snapper richardhehehehe
                            www.overfab.uk
                            • #29
                              there goes another one
                              • #30
                                sorry mate.but the look on your face when you snapped that bolt gives me the giggles every time i think about it.
                                www.overfab.uk
