@tonyN
  • @tonyN
    hi tony just read the thread i started on your mini forum about having to go to dual shocks on the rear,do they do a kit for this purpose on the surf.or is it a home fab job????and while were are on the subject do they do the same for the front??or if anyone else has any info it would be greatly appreciated.
    www.overfab.uk
    Just out of curiosity, why would you do that? Heavier truck? Yours is lighter at the front than most isn't it?
    I suppose two of the same rate would effectively double the rate. Is that correct?
      He wants a MONSTER TRUCK looky likey.
        yea your right andy my truck is about 300kgs lighter than most of yours.but its also a lot taller than most.im having trouble with the rear suspension being a bit on the non responsive side.so i think tony has suggested fitting a dual shock set up to take into accordance the extra height.
        www.overfab.uk
          I will be making some for the 2 door surf, front and rear.
          The fronts are quite easy if you make you own shock hoops, and I'd probably ditch the anti roll bar, and have a shock either side of the front prop and up to the hoop.
          The rear is more fun, probably easier to run them like the MK2 and up pickup, and angle them in at the top, to any sort of bracktery fixed to the tube that run between the chassis.
          The bottem I'd fab a bracket that welds or clamps to the axle tube, with fitting for the lower eyes of the shocks.
          Big tyres take a lot of damping. 9000 or simular gas shocks will help with the rolling momentum without overly stiff springs as well.
            The fronts are quite easy if you make you own shock hoops, and I'd probably ditch the anti roll bar, and have a shock either side of the front prop.
            got any drawings or pics of the front set up tony.
            www.overfab.uk
              Its all in my head!!
              Have a search around on the US websites, they have done it plenty of times.
                ive got a can opener.is that any good. ok cheers mate ill have a looky on yotatech.p.s did you get that bender yet???
                www.overfab.uk
                  Like this?
                    Originally posted by marky
                    Like this?
                    that first one is a savage lol
                    these are better
                      Vatch why didn't you just get a unimog chassis and running gear and put a surf body on it ,,,,,,It would have saved time
                      www.daemon4x4.org
                        A unimog Thats a dangerous animal is'nt it
                          hind sight is such a wonderful thing.WHY DIDNT YOU MENTION THAT EARLIER.
                          www.overfab.uk
                            only if its in my hands
                            www.overfab.uk
                              Yes and you would still be looking for ways to lift it higher and fit 66" wheels
                              www.daemon4x4.org
