Inner CV Joint requiered
  • Inner CV Joint requiered
    I'm after a near side "Inner" CV joint (the one with the 6 bolt holes in, near the front diff) for my LN130 but milners and roughtrax don't seem to supply them. I have only looked on their web-sites and I have not phoned them.
    Does anyone know where to get one from and how much they are?
    Thanks,
    Rob.
    I like Orientals
    Will this do?
    http://cgi.ebay.co.uk/TOYOTA-LUCIDA-...QQcmdZViewItem
    Or try your toyota dealer in the morning, sometimes they are as cheap as every body else, or they can tel you if any of the others will fit.
    Some of the other 2.4 jap import vans might fit.
    Rob
    Still working for the man!
      No not that one, that's the "Outer" the one that slides into the hub I can get them in a lot of places.
      I need the inner one that bolts onto the front axle.
      I like Orientals
        How desperate are you? I've probably got used ones lying around.
          Not too desperate, it starts making a noise at about 50MPH. It sounds like a Wheel bearing wine but it must be the CV because I was running on a split Boot from November 06 to early febuary 07.
          I like Orientals
