@woodzie.
  • @woodzie.
    should look something like this .sorry bout the crude drawing mate.
    www.overfab.uk
    right i found a photo of what i eventually did ....There was alot if cutting
    see red lines
    Finnished up like this http://www.hiluxsurf.co.uk/forums/sh...0&postcount=76
    www.daemon4x4.org
      I recognise those bits you naughty boy !!!!!
      Working at last.......
        yep but put to better use
        www.daemon4x4.org
          see red lines
          you certainly made a nice job of it .looks the dogs danglies.
          www.overfab.uk
            Yeah but your will be TWICE as good
            so you will need two rubbers plus a couple spare
            www.daemon4x4.org
              thats ok they come in packs of threes dont they?
              www.overfab.uk
                Yes they are the only decent bits we make that can be used on our trucks. When you get a chance to see it, Ian has made a really good job of it, i saw it as a work in progress and you got to have ba$$s to do it. By the way Ian i sent you a pm did you get it?
                  when you fit a snorkle do you have to keep the air filter or is it optional?
                    Yes you need a filter in the system..... Snorkels were designed to be a high level air intake , be it dust or water But you still need to filter out the particles before the air enters the engine
                    AND YES LURCH I DID GET YOU PM
                    www.daemon4x4.org
                      cool thanks for the info
