sunroof
  • #16
    im not sure i would do that,
    1. i cba
    2. i have a watch
    Alex
    • #17
      Are you a dwarf?
      Not that short.
      • #18
        i always thought you were for sum strange reason
        Alex
        • #19
          Originally posted by vatchman
          ive got it,cut part of the rim of the steering wheel off,a bit like K.I.T.T.THEN YOU CAN SEE THE CLOCK.
          Well, these are usually reserved for G.B, but I think you've earned one.
          • #20
            it beats having a stupid boy one off of vince.
            www.overfab.uk
            • #21
              • #22
                you can wind the sunroof out manually,flip the plastic case down between the sunroof switches and turn the allen screw inside.
                tryed that already but all it does is clicks, any other way to do it?
                • #23
                  If you try to open it by the motor what happens? I know it doesn't work, but does it make any noises or anything?
                  =SOLD UP!=
                  • #24
                    yep, i can hear the motor running. but all it does is clicks like a chain slipping.
                    • #25
                      sounds like the worm gears broke, ahh bugger it if you can wait i'll do it tomorow on mine and take photos, show you how to open and close it manually, the winder on the motor still uses the worm gears to operate.
                      But basically, there's a clip either side towards the back of the sunroof, you gotta release by hand. So the back of the glass can drop down and slide into the roof like it would if it were working properly. Once you done this you can slide the glass back,
                      et voila! - You still got a sunroof that don't work, but you can get the visor off.
                      =SOLD UP!=
                      • #26
                        thanks i'll wait on baited breath for the pics lol,
                        cheers for the help
                        • #27
                          Originally posted by RodLeach
                          open the sunroof and then undo 4 screws, 2 on the front and 2 on the sides, then just pull out the clips! an Bingo!
                          cant find these 4 screws, is this looking from the top, any pics would help
                          • #28
                            Yeah looking down from the top, They are near the edges.....I'm assuming its a factory Toyota visor?
                            • #29
                              take it you got it open then? Don't forget to slide the clips forward when you close it otherwise it can be opened from outside.
                              =SOLD UP!=
                              • #30
                                yeah i got it open but there is more than four screws heres a pic can anyone point out which are the screws?
                                http://www.toyotasurf.asn.au/techsit...%20runners.pdf
