Lift Questions
  • Lift Questions
    OK one of my questions was partially answered on Jacksters thread regarding the fuel filler, but i'm not sure if ya only have to loosen it if your doing a 3" lift
    or a 2" as well, suppose it's better to loosen it anyway and be on the safe side,
    The other question is has anyone done a lift with a Jaos bar fitted? it suddenly occur'd to me that the uprights return over the bumper top a bit
    (see the pix) so any messing with the clearance between body and chassi is gonna throw that out and the bars wont fit unless i make up metalwork to alter the jaos brackets, (which i dont really want to do) if this is going to be a major pain i'll leave it a just do a suspension lift instead, although the main reason for a body lift was to help with fitting the intercooler
    I'm in two minds about this now! Thanks Ian and Ian
    best to loosen the filler pipe aswell Ian.I took my wrap around bar off as i will have to cut 2" of the top where it goes over the bumper as in the pic and then i will get it put back on,the stabiliser brackets will have to be modified aswell i think but wont know till i get to put it back on
      ian i would undo the filler clips anyway.we had to take stormys bar off and modify it when we did the lift.i cant remember if we re fitted it though it was kinda late in the evening.stormy will tell you.
      www.overfab.uk
        I think you need to do the suspension lift if you wish to keep the jaos
        www.daemon4x4.org
          ok pipped at the post,i guess we didnt refit it then.
          www.overfab.uk
            Cheer's Richard, cut the bars!!! i did'nt think of that, i was dreaming all sorts of complicated bracket'ry to get over it, guess thats why i'm on the lower money
              Cheers Vatch
              Bit confused as to why i'd need a suspension lift as well to keep the bars though, unless i'm missing summat
                Cheers Vatch
                Suspension lift instead of bodylift.
                  $hite!! hope i aint put meself in the frame
                    Not in my book any way i was a little cryptic
                    www.daemon4x4.org
                      What happened i'm sure tony posted here Moderated
                      www.daemon4x4.org
                        hehe yea i saw that too.
                        www.overfab.uk
                          Oh well i better go back to my coffin in the cellar
                          www.daemon4x4.org
                            It wasn't that funny in hindsight, I binned it.
                            Someone needs to keep the funneys high quality.
                              left my bars off ian ,,,,,couldnt be bothered to muck around
