workshop manual
  • workshop manual
    Where can i get a workshop manual for a M reg 3.0TD
    If this is not available can one of you guys post the specifications.
    mostly head touqes, tappets, fluids ect.
    :cough:
    http://www.yotasurf.co.uk/Forums/showthread.php?t=62 :/cough:
      Better to get the workshop manual for your particular engine from Toyota as some of the data on the link above is inconsistent with my manual. The above says 7 & 8 litres for oil whereas the OE engine manual from Toyota says:
      1KZ-T (3.0 L Turbo Diesel) engine oil: 6.4 litre (without filter change); 7.1 litre (with filter change); 7.4 litre when "dry" filled.
      As to torquing values etc you will definately need the above manual. I've got a copy at home so if you email your reqs off list I'll see what I can do.
      @africa4x4cafe
      [url]www.africa4x4cafe.com[/url]
        Sorry forgot my email:
        enzo@bundubasher.com
        @africa4x4cafe
          @africa4x4cafe
            have a look at this http://www.showmesome.info/hilux/info/manuals/1KZ-TE/
            [size=5][/size]
              The part no. for the 1KZ-T manual is: RM353E.
              In section EG-246 (Engine - Lubrication System) there are two choices: KZJ (KZJ70, 73 & 77 series landcruisers) and the KZN (KZN130 being my 3.0L TD 4Runner's chassis model).
              But check your engine/chassis numbers to confirm before you purchase.
              By the way there is a repair manual for the chassis and body: RM158E
              @africa4x4cafe
