I've just had to replace the rear fog light because the last one was full of rusted water and sludge and had stopped working.
I picked up a bog standard one from Halfords, and fitted it last night.
However, every time I switch the fog light on, it blows the fuse to the side lights. There is obviously a short somewhere, but cannot find it.
The other problem is that I have my MOT tomorrow, so have to try and sort it tonight.
As far as I can tell, the fog light wire connects to the side lights SUPPLY load and the GND, runs to a switch on the dash, then runs along the driver side to the light. When the light is disconnected and the switch and side lights on, my testers are saying there is 11 - 13 V running along the wires.
As soon as I connect it up, I get a spark and the fuse blows.
CAn anyone suggest where I might be going wrong? If the wires have rusted a bit at the ends, would that cause a short? I tagged some 8amp wire onto the ends to get the right length, so could this be the problem? Do I have to use 5amp?
What about increasing the size of the fuse?
Any ideas would be greatly received.
