Mains electrical advice needed please
  • Mains electrical advice needed please
    Hi
    I have a problem with my electrics at home something in the garage is causing
    the main trip on the electrical box to trip out. What I cant understand is why it is tripping the main switch and not just the Garage trip which is fused at 16amp this is what usually trips when something causes an overload. I know I can isolate the garage for now but that doesnt solve the problem.
    Thanks for any advice
    Trust your Hound.
    I will probably get shot down by someone later (Matt), but maybe the garage trip is not on an earth leakage breaker? Therefore if it's an earth fault the main elb would go???
    Nil illegitimi carborundum
      Could you explain that please (i am not electrical minded) How do I cure the problem
      Trust your Hound.
        Well to start with I'd turn off everything in the garage, reset the trip and turn on everything slowly untill the trip goes. Remember what set the trip, turn everything off, reset the trip then turn on the offending item. If it goes the problem is with the bit of kit that set the trip, if not the problem is more likely to be overload, in which case you are running too much on the spur.
          you need to find the fault that tripping house fuse switch
          turn all off in the garage then reset house trip and one by one switch on garage electrics starting with your garage fuse isolator
          see what happens then
          THAT MEANS WOT ACE JUST SAID 1 POST UP
          Enjoying Life after Cancer
          Pops
            I have done that and everything is OK. When it tripped this morning the wife tripped over the wire on the vac while vaccing up (in the garage which she also uses for dog grooming). What I cant understand is
            A) why is this happening now everything was OK. for 8years.
            B) why is it not tripping the16amp trip.
            Trust your Hound.
              maybe loose wire connection on the hoover mate
              since you reset has it gone again
              and have you plugged hoover in again to see if it happens again
              (mind that hoover lead you may trip on it )
              Pops
                I'd agree with that, sounds like tripping on the hoover cable pulled a wire in the plug!
                  And it sounds like there's no RCD protection on the 16a trip, therefore it's tripping the main.
                    possible and us blokes do like to know for sure dont we.
                    you not said if its tripped again or not i assume its not then yes
                    Pops
                      anyway why she hoovering the garage thats just not done old boy you need to take up the slack on the ball and chain there
                      Pops
                        Sounds about right to me. The fault isn't an overcurrent fault (which will trip a conventional mcb) but an earth leakage fault as you say, which trips the main ELCB at the main box.
                          Eveything seems OK now no its not tripped again. but it has tripped before with no appliances plugged in??
                          Trust your Hound.
                            Had a similar thing a few years ago when we moved into a new house, everthing was ok till we tried to use the henry hoover( 1000watt).
                            Tried all the usual stuff and then called in a sparks, took him 90mins to trace a loose neutral conection on one of the internal sockets.
                            Not saying that this is the fault but thats what it was with ours.
                            Rob
                            Still working for the man!
                              What is an earth leakage and how do I fix it??
                              Trust your Hound.
