Originally posted by jotto
cooler, even under load, isn't the problem. As you obviously know, choosing
the correct size cooler and siting it correctly will keep the ATF fluid cool.
However, my point was that neither do you want the ATF fluid TOO cool.
That's why not passing it through the rad cooler would not necessarily be a
good idea. An external ATF cooler alone can only control the upper temperature.
It has no way of controlling the low temperature range. As with the engine, the
auto box has an optimal operating temperature. That's why even race
cars have a thermostatic switch to control when the fluid gets passed to
the cooler. However, unlike domestic vehicles, they will never be stood for
periods of time which would allow the ATF fluid to cool down to any degree,
so overcooling doesn't arise in that scenario. Domestic use, however, it can.
